Help with Java code
Go to solution Solved by madknight3,
Thank you but do i'm still not getting this :/. Do you know why it should be 8 characters long?
I'm reading the article but its way above my level. I've never heard of a string argument.
It will append white space before the String if it is less than 8 characters. Here's an example how different names would look.
   James   Laura    Sara  Alexis Matthew
I assume that was the desired effect and why "%8s" was used.
Hi I'm creating a program in BlueJ (java) and I have some code my teacher gave me and never explained. I has managed to fit the code into my program but in order for me to proceed with the next step I will need to understand the code. Its only losing a mark if I don't do this but overall worth 15 marks of my grade so help is really appreciated. I unfortunately can't show you the rest of the program because that would be cheating but an explanation would really help.
The code below is code which chooses a random name from an array of five names. It then displays a message to the winner. It runs the loop once.
My other question is why is "%8s" being used?
  for(int i=0; i<1; i++)
             // Generate random number 0-5
              reelSpin=(int) (5*Math.random());
              // Display corresponding names
             System.out.printf("%8s", Names[reelSpin]);
Thanks, help appreciated.
Computer Spec: CPU: i5 4690K @ 4.85GHz Delided    Motherboard: ASUS Maximus VII Hero    RAM: Corsair Vengence 2*4GB    GPU: Gigabyte G1 Gaming GTX 970    PSU: Corsair RM650    Boot Drive: Crucial MX100 256GB SSD    Storage: 1TB WD Blue HDD   Case: NZXT H440 Red and Black
Cooling: EK PWM D5 Pump & EK 140ML RES Combo unit , EK Supremacy Evo CPU Block , 360mm Alphacool Radiator , 3 Noctua NF-F12 Fans on the radiator , Some fancy fittings
https://linustechtips.com/topic/341590-help-with-java-code/
It's a string argument.
% signals the argument.
8 means it should be 8 chars long.
s means it's a string.
http://javarevisited.blogspot.ro/2012/08/how-to-format-string-in-java-printf.html
https://linustechtips.com/topic/341590-help-with-java-code/#findComment-4654427
https://linustechtips.com/topic/341590-help-with-java-code/#findComment-4654494
https://linustechtips.com/topic/341590-help-with-java-code/#findComment-4655014
