Hey guys
So I recently purchased a Sceptere X20G-Naga III from Goodwill. I tried it out using VGA when I was there on a store computer and everything appeared to be in order, so I bought it and took it home. Now, unfortunately, when I got home, when I tried plugging it into my laptop's hdmi port and the monitor's dvi port over this converter cable, I couldn't get anything to detect, let alone display anything. I know the display works, since I can still get it to work over VGA on different computers, but unfortunately my laptop only has an HDMI port and I know that converting digital to analog is a real pain, is expensive relatively, and isn't bulletproof by a long shot. Also, I know for a fact that the converter cable works as well, since I can get other dvi monitors to work using it with my laptop.
The one thing that still gives me hope that I can get the display to work over dvi is the fact that when I have the Sceptere plugged into my laptop, and when I have display settings opened in windows, if I wiggle the power cable for the display till the point where sparking can be heard, the display flashes grey and is detected by windows in display settings (shows the monitor name, resolution, stuff like that) for a brief moment, and then it loses connection with it.
So anyone have any idea what may be going on here and what I may be able to do to get the display working properly?
Thanks.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/341444-need-help-getting-a-display-to-work/
I tried getting a VGA monitor to work with my PS3 through adapters. Like you said, I don't think it's possible without spending a tonne of money. IDK really though sorry :P
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
Half the cables you find on amazon are super cheap and won't work because they're supposed to be passive adapters and you need active or semiactive converters to be able to convert digital to analog. The other half of the adapters have both really positive reviews and really negative reviews so they're only somewhat sketchy at best.
Hey guys
Thanks.
This should be okay I think
http://www.amazon.co.uk/Cable-Matters-Active-Female-Adapter/dp/B007SM7O2U
My rig:
