My Revised First Build
Go to solution Solved by zlolslavez,
Going intel can save you money (and if you give 2 shits then power will be lower aswell)
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.99 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.99 @ SuperBiiz)
Video Card: Sapphire Radeon R7 260X 2GB Video Card  ($114.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($37.99 @ SuperBiiz)
Total: $414.57
Generated by PCPartPicker 2015-04-04 11:43 EDT-0400
this also gives you 8gb ram
So a few days ago I posted what I wanted to build for about $400, which you can find here:http://linustechtips.com/main/topic/339714-my-first-pc/
After reading comments and getting some feedback, I think I have got a pretty good build.
PCPartPicker part list: http://pcpartpicker.com/p/K6ynrH
Price breakdown by merchant: http://pcpartpicker.com/p/K6ynrH/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($93.95 @ SuperBiiz)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard  ($89.99 @ NCIX US)
Memory: G.Skill Ripjaws X Series 4GB (2 x 2GB) DDR3-1600 Memory  ($36.97 @ NCIX US)
Storage: Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive  ($27.00 @ Amazon)
Video Card: MSI Radeon R7 265 2GB Video Card  ($130.98 @ Newegg)
Case: NZXT Source 210 (White) ATX Mid Tower Case  ($37.99 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Total: $461.87
Generated by PCPartPicker 2015-04-04 11:36 EDT-0400
In the comments, it would be helpful if you can tell me any way to help lower the price down. Thanks for reading this and make sure to comment.
https://linustechtips.com/topic/341366-my-revised-first-build/
Total: $414.57
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/341366-my-revised-first-build/#findComment-4652193
With only $400 I would get a nicer AMD APU then get a dedicated graphics card later on when you have more money. I dont think the R7 265 would have much better graphics then one of their nicer APUs.
I would agree with this^^^ if you want to go AMD which i dont recommend
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
https://linustechtips.com/topic/341366-my-revised-first-build/#findComment-4652197
Total: $414.57
this^^ would be a better solution
https://linustechtips.com/topic/341366-my-revised-first-build/#findComment-4652201
