Hey guys, I currently have a pretty mediocre office/home pc that I bought about a year or so ago. I want to get it up to a decent standard to be able to play some games I have such as sniper elite 2, battlefield 3 and rust. I have £200 ($300 USD) to spend and my specs are as follows:
CPU: AMD A6 5400K @3.6 GHz (stock)
Cooler: Stock
Motherboard: HP stock w/ wifi 802.11n/b/g
RAM: Samsung 1x6gb @1333 MHz
GPU: NVIDIA gt620 1gb
HDD: Samsung 1TB 7200rpm
PSU: Noname 300w
Case: HP stock w/ 1 rear exhaust fan
That's pretty much it, I would like to know what you guys think I should upgrade, as I was going to go for:
GPU: Gigabyte r9 270x
Case: Fractal Design Core 1300 or 2300
PSU: Corsair CX430W
Which is bang on £200- anything you would change? Thanks!
https://linustechtips.com/topic/341311-need-help-upgrading/
You should bump up your CPU and GPU it will make a ton of difference. If you wanna keep the same motherboard go for the 6800k since it's a quad core at 4.0ghz so it will help (though not as much as a platform change)
The GPU the best you can afford, really almost anything is better than that GPU. 750ti or a 960 if your budget allows.
On the long run however, you really need a new PSU. Like, badly. And FM2 as a platform will never get you more than 4 weak cores which is significant since even an intel dual core will match and surpass even the best APU so you should be looking at 1150 instead.
Current Rig
https://linustechtips.com/topic/341311-need-help-upgrading/#findComment-4651570
idk...
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  (£161.95 @ Scan.co.uk)
Power Supply: be quiet! POWER 2 400W 80+ Bronze Certified SFX Power Supply  (£52.75 @ Dabs)
Total: £214.70
Generated by PCPartPicker 2015-04-04 14:51 BST+0100
https://linustechtips.com/topic/341311-need-help-upgrading/#findComment-4651589
well your upgrade...if the board will fit in the case..isn't too bad
tho change the corsair psu to a seasonic one..450w or a xfx one
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/341311-need-help-upgrading/#findComment-4656630
