hello!
my budget is 2000 euro!
plz write up a good system for that money
i gonna use my new computer for
gaming
editing
watching films
recording
write down what system you should buy for that money!
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/34076-build-a-system-for-me/
i already made threads about whati shoud do what shoud u do for 2000 euro?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436825
Why do you keep making these threads? Just pick a build and go! Trust yourself, you can always upgrade down the road
okay!
this is a cpu question now:
how long time do you socket 1150 gonna live?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436833
what do you eman upgrade down the road``?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436836
okay!
Till the next one comes out, which will definitely be better than haswell
You can change your components in the future...
RAWR signature became a bunch of HTML codes
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436841
ok thx but do they gonna make more cpus for socket 1150? for example 5770?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436844
okay!
It is already dead platform.
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436855
not sure but most probably for broadwell CPUs.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436859
which is that socket? broadwell?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436868
why is is dead if it got haswell cpus ?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436870
What you need is a high-end graphics card, a decent processor (minimum quadcore from Intel (or octocore from AMD)), a good and reliable motherboard with the features you need for editing and recording, 32GB of high-clocked (and/or overclockable) RAM  for the editing and recording (16GB if you're not editing large files), a colortrue, bright and high resolution screen, probably a soundcard (and some good speakers), a keyboard and a mouse that you find comfortable and practical to use, a reliable and capable PSU, a nice and practical case of your choice, maybe a aftermarket cooler for your CPU and anything else that might be of use to you.
Just try to pick parts that fit your budget and that are compatible with each other. Post them here and let us check if your config need some changes or modifications.
Wi RoZ
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436872
wa? 1150 may support broadwell cpus. the haswel refresh.
http://uk.pcpartpicker.com/p/1eNpF
cheap build. what else do you want/need?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436876
i render up to 400 gb fraps records:DDD
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436877
what is your current pc?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436880
CPU: Intel Core i7 2600 @ 3.40GHz
RAM: 12,0GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard: PEGATRON CORPORATION 2AB5 (CPU 1)
Graphics: SMS24A350H (1920x1080@60Hz) 1024MB GeForce GTX 550 Ti
Hard Drives: 2x 1397GB Seagate ST31500341AS (SATA)
Optical Drives: hp BD E DH12E3LH
Audio: NVIDIA High Definition Audio
gonna sell my sandy brigde for like 170 euro for i cant use it in new build becuze its a 1155 socket cpu
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436897
Whatever you end up getting for your rig, and if you really do that much rendering than the big difference between a Titan and a 780 is that Titan is much more superior in terms of rendering rather than FPS, you should get a capture card. It's not ecconomical to RAID 0 SSD's for FRAPS recording becuase you won't have enough storage on two of them unless you pay quite a bit of money. It would be cheaper to buy a $200 capture card, I don't know how much that is in Euro's, that will keep your fil sizes down and make it easier to record without any excess system stress and you get the benefit of having an easy file format(mp4) to work with for editing rather than the massive uncompreesed FRAPS video which can take an age to render
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436903
By recording, you mean audio recording or gameplay recording?
gameplay recording
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436916
do capture cards destroys good fps```?
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436917
Oh, i was thinking that you are talking about 1155. :)
Sorry.
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436920
Sorry.
no more socket 1155 for me i fell in love in haswell!!
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436931
Sorry.
so 1150 socket gonna live along time
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436941
go with an mvidia card for shadowplay.
https://linustechtips.com/topic/34076-build-a-system-for-me/#findComment-436960
