Need help with Analog speakers.
Because of the impedance this is going to be a little bit more difficult. JVC has really built this so the speakers can only be used with this setup. Basically, this is how it goes:
JVC built each speaker cabinet with 2 separate sets of speakers. The speaker cabinet, what you probably call the "Left or Right Speaker", actually has separate speakers in each one. Usually a manufacture will wire all the speakers together inside the cabinet so they create one single output. In this case, your manufacture has made the subwoofer and midrange speakers a separate wiring all together. Not only that, they have put them at a very odd impedance.
End result - You're either going to need 2 amplifiers (one for both of your midranges, and one for both of your subwoofers) OR one single amplifier that can handle all 4 speakers (which is going to be a rare case or extremely expensive.
My honest suggestion would be get new speakers with a new AMP and call it a day... This setup isn't worth putting more than $75 into. Maybe you can open up the cabinet and salvage the amplifier some how and just get a new source for now.
If you'd like me to try to find a suitable amp for the speakers still, let me know and Ill give it a shot. But I'll be honest, I truly think you're better off floating about $200-250 on a whole new setup.
