So a friend of a friend was having issues with artifacts on ESO and ESO only.  No benchmarks or games were causing the artifacts.  I rebuilt the PC with a new board, CPU, PSU, graphics card, SSD and reloaded Windows.  Entirely new PC and it's having the exact same issue.
Before specs:
Intel Pentium G3220
ASrock H81M Board
2x4GB DDR3 Memory
EVGA GTX 750 1GB GDDR5
EVGA 500W PSU
Kingston V300 64GB SSD
New Build
Intel Core I5-4460
ASrock H97 Pro 4
Same ram
EVGA GTX 960 4GB GDDR5
New EVGA 500W PSU
Kingston Fury 240GB SSD
Intel Core I7-4790K 4.5GHz 1.225V, NZXT Kraken x60 AIO Cooler, EVGA Z97 FTW Board, Kingston Fury 2x8GB DDR3 1600Mhz Ram, EVGA GTX 980 TI SC+ ACX GPU, Corsair Air 540 Case w/ 3x120MM & 3x140MM Cougar Red LED Fans, EVGA G1 650W 80+ Gold PSU, Crucial MX100 512GB SSD, Samsung UD590 4k 60Hz Monitor
https://linustechtips.com/topic/340190-elder-scrolls-online-pixelation-issue/
I think it may just be a bug in the game since it happens to me too sometimes.. in those instances, I can see the programming checkerboard and all the players but no walls..
i7 4790K - MSI XPower Z97 AC - 32GB DDR3-2400 Avexir Sabranco - ASUS Strix GTX 980 SLI - ASUS Xonar Essence - Phanteks Enthoo Primo - RoG Swift + Samsung 28" 4k UHD - Logitech Z906 5.1 - Custom Water Cooling Loop
Mobile: Samsung S8 Plus | Headphones: Audio Technica ATH-M50X / ASUS Strix Pro | Laptop: Alienware 17 R2
It's the pop up menus and the load screens.  Everything in game appears to be fine.
its not hardware related for sure.
I don't believe so either but not 100% sure.
post-187928-0-21986900-1428003363_thumb.
/bump
You change any of the graphics settings within the game or within NVidia Control Panel?  I have the game myself and never encountered this problem.
We can, I set it to max though.
Well before setting anything to MAX, try at the lowest setting first and then work you way up.  When you say, "I set it to max", what settings did you set to max.  Are you talking about in game or are you talking about NVidia control panel.
Did you do anything to alleviate this problem or does this problem still exist sporadically?
I have a potato!
 It was set to high so I moved it to max settings (in-game).  He came over and tested it and everything was fine.  He plugged it in at home and BAM the terms and conditions section is a giant box of pixelation.  Tech support had him remove the user settings file and he made it into the game so far.
