Hey Guys, first time posting here so forgive me if this is in the wrong section or I'm breaking some rules!
Just purchased an Intel i7 4790k, (16 PCI Lanes), going to be running Dual SLI GTX 980's (there goes the 16 lanes) and I have a wireless card that I plug in via a PCI slot on my motherboard. My dilemma that just arrived to me is with my dual 980's taking up all 16 lanes, will this render my wireless card useless? could be a real stupid question, but starting to freak slightly haha
https://linustechtips.com/topic/340004-cpu-lane-compatability-help/
What is your motherboard?
Crosshair VIII Dark Hero | 5900X | NH-U14S | Asus X Noctua RTX 3070 | MP600 | 850 EVO 250 GB | Caviar Black 5 TB | SS-860 XP2 | Define R5 Black | Thaulab Varna IV -> Objective 2 -> Sennheiser HD-555/AKG K7XX/Audiotechnica ATH-M40x
Could you explain how you came to that conclusion that the card will work, just want to know what I overlooked or didn't understand, cheers
Your motherboard has a PLX chip, meaning that it can share the bandwidth of the 16 lanes to other cards. Your GPU's won't get the same bandwidth to the CPU, but it will run almost without any performance decrease.
Your motherboard has a PLX chip, meaning that it can split the 16 lanes to be able to run more than just 2 8x GPU
If Nvidia requires atleast 2 8x slots to run SLI, how does a chip pull an extra one slot out of seemingly no where ( to me anyway) ?
I edited my post. They do offically require 8x but they technically don't need it to be able to operate. Your motherboard therefore gives your GPU's less bandwidth to be able to run additional things.
ok thanks mate, hope to this works then haha
we rent, so I cant get any extra cables routed through the house :( wifi for me
WIFI cards are using the X1 PCIE slots which are driven by the motherboard chipset itself, not the CPU...therefore they have no impact on the PCIe lanes from your CPU which are used only for your GPU's.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
powerline adapter kit would work fine for you then
no need to cut holes in walls then
I may have been misinformed, but I was told that the powerline adapters have to be plugged in to a line that is on the same circuit in order for it to work correctly. In other words the wiring needs to be controlled by the same circuit breaker. If I was informed incorrectly that would be nice to know. If not, then the op would need to be plugged in to a socket in the same line.
It's always a good day if you woke up breathing.
The PCI lanes are controlled by the chip set, not your processor. If I had 16 lanes on my CPU, and let's say to x16 slots, and 15 x1 slots, I could fill up both x16 slots, and all of the x1 slots without affecting the bandwidth of either. The PCI lanes are controlled by the chip set, not the CPU.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
