I need help with two things.
Go to solution Solved by Equilibrium_FOOL,
Connect the server to the internet, and see if you can find it in the "network" tab in Windows explorer.
The first problem that I have, it is really my only problem is that I need help connecting my sever to my computer. I built the sever about 3 days ago and the reason why I built it is because my computer its self is almost at its complicity of memory. I am good with networking and all of that fun stuff , I have any clue how to connect my sever and keep my internet at the same time. If any one can help me please let me know
My other question that I have isn't really a problem. I know this might be a stupid question but is there anyway to play ps3 games on a PC. I can hook my ps3 controller to my PC but I can not play my ps3 games. I have tried to look up tutorials but they are all stupid. The only reason why I can hook my ps3 controller to my PC is because I have a software that lets me do it by USB. I know it may be a stupid question, but if anyone does know please tell me.
Nightraver47
https://linustechtips.com/topic/339796-i-need-help-with-two-things/
To answer your second question, no, unless you want to use some emulator, but you will never have the full experience.
Edited spelling error
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
Connect Internet cable, pc cable and server cable to a switch.
Make sure your server has the correct network adapter settings, give it a static ip.
I asume it's running Windows?
Share the hard drives on the server and then setup a network drive on your pc pointing to the server.
