So there is a slight static sound, my PC is plugged into a the wall. Does anyone else have static with the hyperx clouds? its nothing crazy. In audacity it doesn't even show a wave difference.
Any way to fix it?
https://linustechtips.com/topic/339783-hyperx-clouds-static-sound/
using them right now and no. is this happening on other headphones you plug in
EDIT: and are u using the back audio connectors
The only other mic i had was a $15 USB mic. An yes there in the back.
does it happen on other devices? most likely your onboard audio has interference.
Check if the cable touches the ground if you homes electric installation does not have the 3dr ground cable, if not it is just interference in your case or you have "hear the microphone" enabled
LianLi A71F Fulltower - i7 3770k delided + Corsair H60 - G.Skill Ripjaws 16 Gb @2133 Mhz - Sabertooth Z77 - Asrock Vega 56 - Asus Xonar Essence STX - Creative SoundBlaster Omni - 2x Corsair Force GT 120 Gb - 2x WD Green 2 Tb - 1x WD Blue 2 Tb - Corsair K70 w/ Red switches - Logitech MX Anywhere 2.
No i dont here it. Just afterwards or in calls with people they tell me theirs buzzing. yes there is a 3rd ground.
https://soundcloud.com/riptide01141/hyperx-clouds-static
Check another headset on your pc and try the hyperx on another source (like a phone or an ipod), maybe is your soundcard, not the hyperx but given LMG drop them as sponsors for the compleaints they had on their products it might be just the headset...
will a sound card fix the problem?
 If other headphones have the same noise and on other sources are ok then yes, a soundcard with proper isolation will be the solution OR check what is the source of the interfrence (probably the PSU)
Okay. I could get my phone to record and i used my friends laptop and it recorded a lot of static also
Did you try another pair of headphones to see if you get the same results?
its the mic, not headphones
