Hey guys , so I need some help , I bought a couple of Active Pickups (81+60) and it came with the wires and everthing , but I also had to buy a 3 way switch (mine was a 5 way) so i installed the 3 way into my guitar, but now i need help on how to wire the 3 way switch to my guitar.
So I noob question time. What wire do i need ?? like normal cobre wire ? heres a diagrame of the how's the circuit is done
http://gyazo.com/634e44440724d64dd3c656cc0fe5a21e
https://linustechtips.com/topic/339671-need-some-help-on-wiring/
Any nylon coated copper stranded 16Ga or 14Ga wire will work fine. Most hobby stores, any hardware store, auto parts stores. They all carry it.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/339671-need-some-help-on-wiring/#findComment-4630661
Great choice of pickups, loving my 81+85 set. :) You'll be good with any wire really, you may not want to go too big (diameter-wise) as it will make installation a bit harder (not being as flexible and such).
Hehe bought the James "hetset" but like any kind of wire will do it ?
https://linustechtips.com/topic/339671-need-some-help-on-wiring/#findComment-4630667
https://linustechtips.com/topic/339671-need-some-help-on-wiring/#findComment-4630671
https://linustechtips.com/topic/339671-need-some-help-on-wiring/#findComment-4630675
Oh crap .. sorry for the triple post :'(.
Hmm okay will go to my local hardware store and hope they have it xD.
Oh, and are all wires the same ? like the green one , the black one and the white one ?
https://linustechtips.com/topic/339671-need-some-help-on-wiring/#findComment-4630693
Hmm .. so i ask for about 1.5 Meters of 22 AWG ? and about what a about the color that is on the diagrame ? is it just regular wire ?
It'll be easier for yourself if you get an assortment of colours so you can keep track of what's what, but it's not necessary. :) After all wire is wire, the colours are only there to ease install and maintenance.
https://linustechtips.com/topic/339671-need-some-help-on-wiring/#findComment-4630861
Ah okay , Thank you Sooooo much .. i never liked the Electric stuff :\
https://linustechtips.com/topic/339671-need-some-help-on-wiring/#findComment-4630894
Yes they are just color coded for easier trouble shooting/repair.
Top Hat=Classy Monocle=Villain  Top Hat+Monocle=Mr Peanut
https://linustechtips.com/topic/339671-need-some-help-on-wiring/#findComment-4632081
