Dear fellow forum friends, I am going to be getting myself a "new" R9 280X for 100 dollars USD today. and i needed a new powersupply for it, so i bought the EVGA 600B 80 plus bronze power supply, this should have the power to run the 280X correct? the rest of my system is an AMD A8-5500 quad core cpu 8 gigs of ram, a western digital 1TB WD blue and an ocz arc 100 ssd. Thanks in advance for your help!
https://linustechtips.com/topic/339392-280x-power-supply-help/
That PSU will work just fine. It is Bronze rated with a good single 12V rail.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/339392-280x-power-supply-help/#findComment-4627414
That is what i had thought when i bought it, but some of my coworkers at micro center had their doubts.
No worries here. This PSU will work just fine for your system. This won't be the PSU where you can CF 2 R9 280X but for a single card, it is fine.
https://linustechtips.com/topic/339392-280x-power-supply-help/#findComment-4627519
I can say it will be based on weather or not you overclock it. I know the R9 280 I currently use Its pulling all the power it can with the overclock I have on it 24/7.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/339392-280x-power-supply-help/#findComment-4627534
But you run it with extreme OCs :). Even the Titan X or R9 290X will run with a 600W PSU, of course not  with hard OCs, but I think he'll be fine with a R9 280X.
https://linustechtips.com/topic/339392-280x-power-supply-help/#findComment-4627547
True I guess drawing 410W with a single R9 280 is pretty extreme :D
|King Of The Lost|
https://linustechtips.com/topic/339392-280x-power-supply-help/#findComment-4627568
Lol you draw with a R9 280 as much as I do with a Titan X with modded BIOS... you are insane :D.
https://linustechtips.com/topic/339392-280x-power-supply-help/#findComment-4627584
Only slightly insane :P If I could get better voltage control on this 280 it would be easily needing the additional 6-Pin for the PCI-E slots on my board.
|King Of The Lost|
https://linustechtips.com/topic/339392-280x-power-supply-help/#findComment-4627604
So far from what I can tell the Titan X would only make sense with more phases for LN2 or DICE cooling. For performance custom watercooled like I do it is good enough with its 6 and 8 pin. But yeah I think the OP will be fine with his 600W because we play in a different league lol :D.
https://linustechtips.com/topic/339392-280x-power-supply-help/#findComment-4627641
