So today this morning, I decided to turn on my desktop, since I wanted to play some games with friends. I usually use speakers when playing with friends, and I use my macbook to skype. My macbook was out of battery, so I had to plug it in the electrical outlet. However, the outlet gave a gigantic spark and fried the tip of my charger. My desktop computer turned off completely when this happened.
Desktop Specs:
Specs of current system:
Nvidia Gigabyte GTX 780ti GHZ Edition
i7 5820k
Fractal Design Refine R4
Noctua NH-D14 SE2011
Kingston SSDNow V300 SSD - 120GB
Western Digital WD Green 1TB
Cooler Master Thunder 700W
Crucial Ballistix Sport 16GB DDR4 2400 MHZ
Gigabyte X99 UD3 Motherboard
Dell E2214H Screen
Razer Blackwidow Expert 2014
Razer Deathadder 2013
I am really worried now, though i havent plugged it in a another outlet to see if it is working. Is it possible that my components have been fried? Can someone help me with this situation??
Roboslash
Desktop: Processor - Intel Core i7 5820K   Motherboard - Gigabyte GA-X99-UD3   RAM - Crucial Ballistix Sport 16GB 2400MHz DDR4   GPU - Gigabyte GeForce 980 Ti G1 Gaming 6GB Case - Fractal Design R4 Window   Storage - x1 WD Green 1TB, x1 WD Green 2TB, x1 Samsung 850EVO 120GB, x1 Kingston SSDNow 120GB  PSU - Cooler Master B700 (700W)   Displays - x1 Dell E2214H, x2 Dell 1908FP-BLK   Cooling - Noctua NH-D14 SE2011
Keyboard - Razer Blackwidow Expert 2014   Mouse - Razer Deathaddder 2013   Speakers - Logitech Z906 5.1 OS - Windows 10 Pro   Headphones - Steelseries 9H, Sennheiser Momentum
https://linustechtips.com/topic/339284-need-help-quickly/
No i havent yet. i think my outlet is worn out yes, because I plugged my macbook into the top port while my pc was in the bottom one. Im not sure if my pc is working, and i want advice of what i can do.
https://linustechtips.com/topic/339284-need-help-quickly/#findComment-4626138
plug in a lamp to the socket and see if it works fine
like I said tho..I would probably replace the socket as well
they are like 7$ at home depot
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/339284-need-help-quickly/#findComment-4626142
The lamp doesnt work. Im not worried about my outlet really, though could it have caused potential damage to my pc?
https://linustechtips.com/topic/339284-need-help-quickly/#findComment-4626148
a pc should be on its own circuit...or one with very low power draw from other stuff
Never plug a PC directly into a wall. You should always plug it into a surge protected power bar. It could have caused damage but if it powers on you should be fine. Just make sure you get a power bar.
https://linustechtips.com/topic/339284-need-help-quickly/#findComment-4626203
If your powersupply also your motherboard have overpower protection it should be fine.... but you should always have surge protected power bar only cost a few coffees at your hardware store
Magical Pineapples
https://linustechtips.com/topic/339284-need-help-quickly/#findComment-4626253
https://linustechtips.com/topic/339284-need-help-quickly/#findComment-4626262
Ok, thanks for the help. I checked my fuse and turned the switch on again. My pc works fine, so I guess everything is working properly. If it powers on, has there been damage caused?
And yes, I dont plug it directly into the wall, I plug it into a power bar, though I dont think it is a surge protected one.
https://linustechtips.com/topic/339284-need-help-quickly/#findComment-4626263
I thank the fuse for saving me. Though Ill get a surge protected power bar to be safe.
https://linustechtips.com/topic/339284-need-help-quickly/#findComment-4626273
