Hey guys,
My boss wants me to upgrade his system, he has given me a budget of about $150 canadian. His current system is a pentium e2160 (LGA 755), no gpu, and 4gb ddr2(max). i was thinking his best bet is a 250x. is there any other options to save this dated system. all he really plays is WoW. currently he plays at 1440x900 at low getting about 7fps... no idea how he does it.
Thanks for any advice you can give.
https://linustechtips.com/topic/339205-need-advice-on-upgrade/
ya i wish. he shares it with his wife and wouldnt get approval lol probably something i would do for him later.
It probably wouldn't hurt to ask him but I think he will be satisfied with the 250x if he doesn't get approval from his wife.:)
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4625507
the CPU is also the weakest link in the chain
WoW is CPU dependent
I am living with 10fps because of my weak GPU
but in all seriousness the system may need a major overhaul
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4626125
i agree with arc. an A8 upgrade would probably be the best improvement he'd get.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4626713
go for the i3 at least for the budget PC builds
WoW works best with Intel CPUs
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4626721
true but there is no graphics card in pc, an A8 will be a huge improvement for the OP's boss. i certainly agree that an i3 now and a gpu later would be better in the long run though.
My rig:
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4626747
the i3 Intel HD graphics is no slouch
WoW isnt as texting on graphics as you think
it will be fine for what he games
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4626756
That may be so but the cheapest i3 is still more than the price of most A8s and intel's intergrated graphics will not be faster than an A8's GPU.
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4626908
ok this is awesome guys, im not well versed in amd. can you link me a sutible mother board and cpu, his current board is matx but i didnt look at the case to see what size it is. i will probably go back today and take a look inside to aswell. and i guess a new processor would help the overall system (happy wife...)
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4627648
Here you go:
CPU: http://pcpartpicker.com/part/amd-cpu-ad7600ybjabox  or this for overclocking: http://pcpartpicker.com/part/amd-cpu-ad580kwohjbox
Mobo: http://pcpartpicker.com/part/msi-motherboard-a68hme33
Ram: 4GB : http://pcpartpicker.com/part/crucial-memory-bls4g3d1609ds1s00
         8GB : http://pcpartpicker.com/part/gskill-memory-f312800cl9d8gbxl
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4627993
the cheapest i can find these in canada come to $280 with shipping. I dont think that will work for him, he usually just buys big box computers. if i got the 250x would that help any untill he figures out what he wants to do in terms of all new stuff?
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4629533
it will certainly help. it won't make the game amazingly smooth but it will certainly be an improvement over the 7 fps he's getting right now (unless his pentium is incredibly bad)
might be worth cleaning out the dust and replacing the thermal paste while you're at it. if the system wasn't well maintained then his cpu might be running hot and throttling. besides, thermal paste is cheap.
My rig:
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4630596
https://linustechtips.com/topic/339205-need-advice-on-upgrade/#findComment-4630686
