Hi LTT Forum,
I recently overclocked my 4790K and ran a stress test. All day the liquid temp never rose above 40 degrees Celcius, even with fans on low.
The CPU's temperature hovered around 70 degrees. My AIO is the Kraken X61.
Thanks again and hope you guys can help!
Dual Boot Windows & Hackintosh
CPU: Intel 4790K | Motherboard: ASUS Maximus Hero Vii | GPU: Zotac AMP! Extreme GTX 970 | Display: ASUS PB278Q | Case: Phantom 630 | PSU: Corsair HX1000i
Canada eh?
https://linustechtips.com/topic/338797-low-liquid-temps/
Having a liquid temperature of 40C is quite high. 50C tends to be the amount where you should really be getting worried. Reservoirs can fall apart at that temp.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/338797-low-liquid-temps/#findComment-4619791
Try adjusting your fan curve, pump speed and reseating your pump and try to apply less thermal paste.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/338797-low-liquid-temps/#findComment-4621158
