Do you guys know any right sided window cases because i place my case on my left side so i want to play led into my case but no point because it facing a wall. Anyone know any cases like this which has enough room for 240mm/280mm radiator?
Magical Pineapples
https://linustechtips.com/topic/338732-right-side-window-cases/
Cases that have the window on the right have to be inverted either 90 or 180 degrees so the IO is in the correct place.
If you search for inverted ATX cases, you should find some.
H440?
It really hard to find any good cases with a inverted ATX, why so low section range?
Only one i could find which has good amount of feature and good design it origin but you cant just buy the case.
Magical Pineapples
https://linustechtips.com/topic/338732-right-side-window-cases/#findComment-4618887
Silverstone FT02/RV02-E (same structure, different aesthetic)
Silverstone FT04/RV04 (same structure, different aesthetic)
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
https://linustechtips.com/topic/338732-right-side-window-cases/#findComment-4618895
Yea but i want midtower to full tower and the aesthetic is not that pleasing... why cant company make inverted ATX?
Magical Pineapples
https://linustechtips.com/topic/338732-right-side-window-cases/#findComment-4618933
Ft04/rv04 are large mid towers.
Ft04 is beautiful IMO
Silverstone is one of the only inverted atx
https://linustechtips.com/topic/338732-right-side-window-cases/#findComment-4619715
Origin had a special at the end of last year selling just the case for ~$400USD. Are you willing to do inverted mATX? There are a few of those on the market.
https://linustechtips.com/topic/338732-right-side-window-cases/#findComment-4627805
Interesting? I used to have a apevia case the was a cube with windows all around it but it was small and a cable management nightmare.
Super OP AF Killer Retro Emulation PC 360 No Scope 420 Blaze It (Sorry I Couldn't Help It) Seriously Though This PC Is Overkill And Before You Ask It Does Play Crysis 1024x768 60 FPS
Intel Core Duo 2 Quad Q9550 @ 2.83GHz // ASUS P5N-D // Zalman CNPS9500A Air Cooler // 4GB G.Skill @ 400MHz 5 5 5 31 23 // 2 Way SLI GeForce 9800 GTX+ // 32" SONY WEGA CRT TV 480i // Corsair TX750 // Seagate 3TB // Win XP 32Bit // Sony DVD RW // ANTEC Full Tower // Steel Series H Wireless // Logitech K520 Wireless Keyboard // Logitech M510 Wireless Mouse // Logitech G27 Racing Wheel // Thrustmaster T-Flight HOTAS // HORI Fight Stick Mini // 8Bitdo NES30 Pro / FC30 Pro / SNES30 / SFC30 Bluetooth Controllers
Future Upgrades The New 8Bitdo Wireless SNES Controller With Analog Sticks / 8Bitdo Bluetooth Arcade Fight Stick / Proper HD I Know This Machine Does Not Support 3 TB / Icy Dock 5.25 4 Bay HD Hot Swap Bay For More Seamless Multi Booting Want To Run At Least Win 95, Win XP, Win 7
i7 3770k @ 4.5Ghz // ASUS Maximus V Formula // CM Hyper 212 EVO // 16GB G.Skill Sniper @ 2133MHz 9 11 10 28 // Crossfire Sapphire 7970 // 42" 4K 60Hz FreeSync WasabiMango IPS // Corsair AX860 // Samsung 1TB 840EVO // Seagate 3TB // Seagate Barracuda 160GB sata II // OCZ Vertex 3 90GB sata III // Win 10 64Bit // ASUS DVD RW // 2 Corsair AF 120 // 2 Corsair SP 120 // 2 xigmatek 120 // Corsair 760t white flavor // NZXT HUE+ RGB Controller // Sennheiser G4me Zero // Steel Series H // Corsair M95 // Corsair K95 // 3 Xbox 360 Controllers // Dolphin Bar // Wii U Mote // Leap Motion Plus // Logitech G27 Racing Wheel // Thrustmaster T-Flight HOTAS // HORI Fight Stick Mini // 8Bitdo NES30 Pro / FC30 Pro / SNES30 / SFC30 Bluetooth Controllers
Future Upgrades 1080Ti or Vega RX64 http://linustechtips.com/main/topic/16900-nothing-special/
https://linustechtips.com/topic/338732-right-side-window-cases/#findComment-4628341
