I'm kinda new to the world of PC building and I was hopping that someone could point me in the direction of a good build, I haven't been able to decide on any parts and have a limited budget of at most NZD$1500 (USD$1130). For this machine I want to do some entry gaming (Games I am likely to play https://steamcommunity.com/id/Monkey_Man61/games/)as well as some video editing and stuff like that, I would like to do some overclocking but if this isn't necessarily always an option when there isn't allot of room in the budget for the hardware to do so. If anyone could point me towards some components it would be greatly appreciated. (also I am new to the forums so if this isn't the place for this kind of post please tell me so I can fix that)
https://linustechtips.com/topic/338670-pc-build-help/
My suggestion:
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor  ($447.00 @ 1stWave Technologies)
Motherboard: ASRock Fatal1ty H97 Performance ATX LGA1150 Motherboard  ($151.79 @ PB Technologies)
Memory: Kingston 8GB (2 x 4GB) DDR3-1600 Memory  ($100.00 @ Paradigm PCs)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($159.84 @ PB Technologies)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  ($370.01 @ PB Technologies)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($96.00 @ Paradigm PCs)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($124.91 @ Ascent Technology)
Total: $1534.65
Generated by PCPartPicker 2015-03-31 19:48 NZDT+1300
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4618132
My suggestion:
Total: $1534.65
Thanks this looks awesome
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4618158
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($269.00 @ 1stWave Technologies)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($51.75 @ PB Technologies)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  ($493.34 @ PB Technologies)
Total: $1531.73
Generated by PCPartPicker 2015-03-31 20:02 NZDT+1300
More balanced with more gpu power,forgot to change that psu to a 600w one. derp
When everything else Fails,Crowbar IT. - Half-life
Being a Linux user is sort of like living in a house inhabited by a large family of carpenters and architects. Every morning when you wake up, the house is a little different. Maybe there is a new turret, or some walls have moved. Or perhaps someone has temporarily removed the floor under your bed." - Unix for Dummies, 2nd Edition (Found in the .sig of Rob Riggs)
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4618173
Best one
http://nz.pcpartpicker.com/p/HPzgHx
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($347.00 @ 1stWave Technologies)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($165.00 @ 1stWave Technologies)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($96.60 @ PB Technologies)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($89.00 @ 1stWave Technologies)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($82.00 @ 1stWave Technologies)
Video Card: Asus Radeon R9 290X 4GB Direct CU II Video Card  ($542.00 @ Paradigm PCs)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($93.49 @ Ascent Technology)
Power Supply: Corsair VS 550W ATX Power Supply  ($95.10 @ Ascent Technology)
Total: $1510.19
Generated by PCPartPicker 2015-04-01 04:39 NZDT+1300
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4620461
You've got a lot of extra money for the games you'll be playing. That could work on an $800 budget if you plan on 1080p.
The Rig: NZXT H440 M3 (Green and Black) (Ncase M1 coming soon!!) | Intel Core i5-4690k x BeQuiet PureRock Slim | EVGA GTX 1060 6GB SSC  | ASUS H81i Plus | 12GB EVGA SSC @ 1600MHz | Seagate Barracuda 2TB | Sandisk Ultra II 480GB | Corsair SF 450| LG 29" Ultrawide | CoolerMaster Quickfire Rapid TKL | Corsair M65 Black Sennheiser HD 558 (MOD) | Audio-Technica ATR 2500
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4620502
Here is a build if you will be overclocking:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($226.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($100.98 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card  ($329.99 @ Amazon)
Case: Corsair 780T ATX Full Tower Case  ($169.99 @ NCIX US)
Total: $1172.55
Generated by PCPartPicker 2015-03-31 11:51 EDT-0400
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4620539
My suggestion:
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($85.10 @ PB Technologies)
Total: $1534.65
R9 280x??F**king Power supplies need more..So good for only R9 285 & Gtx 960.
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4620623
$1000 is not a limited budget at all. In fact i would recommend spending about 650-750 if this is your first build. Its much smarted to save that money for later down the road for upgrades or just set aside. $650 is really the sweet spot for PC gaming. i would try a gtx 770 and an i5 4460 for your first build.
EVGA GTX 970 - i5 4460 - Enthoo Pro M
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4622663
Total: $1172.55
This build may only cost $1100 in the US but over here the same build would set me back $2000
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4624768
Do they have a pcpartpicker link extension in your country?
https://linustechtips.com/topic/338670-pc-build-help/#findComment-4625189
