Hey Guys,
Currently I own a Entho Luxe case and my current cooling is set up as - Intake Front 1 x 140mm / Intake Bottom 1 x 120 mm And then I have my Outtake Back 1 x 120mm / Outtake Top 2 x 120mm (attached to H100i). So basically, I have air pulling in from front/bottom and blowing out from back/top.
I was thinking about adding an additional 120mm outtake fan since I could to the top. I was curious about whether that was a good idea or would affect my system in terms of having too much outtake fans since I would have 3 outtakes on top and 1 on back. Could I even set it up as an intake? Not sure how that would work since i would have 2 outtakes and 1 intake at the top. Mess up the air flow most likely haha.
Any recommendations/feedback is appreciated.
https://linustechtips.com/topic/337947-question-about-coolingadding-fans/
More exhaust means more dust inside the case through all holes that aren't filtered. Thats why most people go for neutral or positive air pressure. You could have rear fan as intake, if you have problem with temp. If not, I would just leave it as 2 in, 2 out.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
