Custom Wall Mounted PC version 1.0
FEB - 2015
This was my first attempt for a wall mounted PC and I am pleased with the results.
Overall build cost not included computer hardware* are around $100.
Computer Parts Listed Below
Intel i5-4690k OC - 4.3ghz
Corsair Vengance Ram - 2400 MHz
Asus Z97-PRO Motherboard
EVGA GTX 970 OC to 1440 MHz
DIGI-KEY PCI x16 Extender 500mm
NZXT Kraken 280 X61 CPU cooler
Samsung EVO SSD
Intel 510series SSD
Seasonic 750W Gold PSU
Monitor - ACER XB280HK 4K with G-SYNC
Pictures of the Build
post-5410-0-72727600-1427672802_thumb.jp
post-5410-0-59632900-1427672900_thumb.jp
https://linustechtips.com/topic/337919-custom-wall-mounted-computer/
Wow that is really cool!
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
FEB - 2015
Samsung EVO SSD
Intel 510series SSD
Now when the wife ways you have nothing to contribute to the home you can say "woman come check out what Picasso only wish he could create"
Really cool!
A water-cooled mid-tier gaming PC.
That's actually my next project, having a wall mounted computer. But my worry is about all the dust  :mellow:
Anyway, great build and it looks really amazing!
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
