So I'm not that good when it comes to motherboards... I am making a build for a friend and want to know what would be the best mobo for $100 or less and ATX format (32 GB Ram Max at least, pretty standard but just to make sure). It will be with the Intel Xeon E3 1231 so it can't be OC'd (he wouldn't OC it if he could). So with those specs, what would be the best mobo.
https://linustechtips.com/topic/337843-mobo-help/
Asus H97-PLUS?
https://linustechtips.com/topic/337843-mobo-help/#findComment-4607316
Asus H97-PLUS?
Thanks! I'm just looking for a mobo that isn't an OC base thing because that won't happen.
https://linustechtips.com/topic/337843-mobo-help/#findComment-4608832
This is a VERY good motherboard for the price and it happens to have a 14$ rebate ATM...perfect to run the xeon E3-1231V3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157511&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/337843-mobo-help/#findComment-4609352
