USB Cable Device Descriptor Request Failed (Code 43)
Solved by GoodBytes,
USB cable have a max length, and like any other cable, longer it is the higher quality it needs to be. A smaller fault can break the signal or cause issues.
Replace the cable with a shorter one, and see if it works. If it is, then the problem is the long cable.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
4
play_circle_filled
Latest From ShortCircuit:
