I am planning on buying a keyboard from someone in the US and I was wondering if anyone has a good experience with UK Import Tax?
Also it isn't cheap for him to send international from US to Northern Ireland, so if anyone knows a cheap international service that is reliable please do let me know.
https://linustechtips.com/topic/337537-how-does-uk-import-tax-work/
i have bought camera gear from hongkong and its was far cheaper but you don't get a warranty as soon as it in the UK
So you didn't have to pay import tax? I be buying a used keyboard from someone on this forum.
it depends whether it gets stopped. its 20%+ some random amount if it does. thats only if you say the value is under £20 or something though. if you put the actual value of the item then you will get charged.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
Oh don't worry, it will be sent as a gift ;] ;] ;] ;]
might get away with it then. :)
Rig Specs:
yeah i didn't pay import tax so i got a £1200 camera lens for £800 but dont have a warranty if it takes a shit
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
