Mic volume post process
Go to solution Solved by ShearMe,
Pretty much what was I look for, but how do I use it for VOIP (say in games or for TS3)? Only gives me the option of playing it back through my headphones.
Oh, sorry, I probably should have linked the guide - Noise gate for windows
Hi, I'm looking for a 3rd party program to boost my microphone's volume by post processing, kind of like how Manycam gives you the option to enable gain control and use background noise supression. I'm not looking for a way to make the actual microphone more sensitive, but to simply boost the volume through a driver (say from 100% to 200%). Does anyone here know of any good ones?
CPU: i7 5820K @4.2GHz RAM: Corsair Vengeance 16GB DDR4 2400MHz
Motherboard: ASUS Rampage V Extreme Graphic card(s): x2 EVGA GTX980 Ti SC (ref) @1405MHz (SLI)
Soundcard: ASUS Xonar Essence STX II Storage: x2 WD Red 4TB (RAID 1), Kingston HyperX 3K 240GB,
Crucial MX100 512GB Case: Fractal Design Define XL R2 PSU: Corsair RM1000
https://linustechtips.com/topic/337175-mic-volume-post-process/
https://linustechtips.com/topic/337175-mic-volume-post-process/#findComment-4599892
https://linustechtips.com/topic/337175-mic-volume-post-process/#findComment-4599962
