450D Front Dust Filter
Solved by W-L,
I've been contemplating on whether or not to get the Phanteks Enthoo Pro or the 450D. However, I am a bit concerned of the issue with dust build-up within my rig with the 450D since the filter doesn't seem to be fine enough to capture a lot of the dust. So if anyone with a 450D please help me out and tell me if the filter on the front is good enough to keep all the dust out I'd really appreciate it!
it looks more like a mesh netting than a filter type material, I would suggest to replace it or get some better mesh, I know DemiFlex can make custom filter meshes that are very fine, so it does cause some extra restriction though.
