pump problems
Go to solution Solved by W-L,
i need a laing D5 pump and i found
EK Water Blocks EK-D5 PWM Pump but can this plug into the NZXT Grid+? or just my motherboard Asus Maximus VII Formula Intel Z97
plug it into the motherboard, mainly CPU fan header since it will give you a warning if your system fan or pump in this case fails, also it will allow for PWM control that the NZXT grid would lack.
https://linustechtips.com/topic/336441-pump-problems/#findComment-4591718
