Hmmm.. try to remove the CMOS battery on the motherboard, wait a few minutes (10-15) then re-seat. See if that works.
i7 4790K - MSI XPower Z97 AC - 32GB DDR3-2400 Avexir Sabranco - ASUS Strix GTX 980 SLI - ASUS Xonar Essence - Phanteks Enthoo Primo - RoG Swift + Samsung 28" 4k UHD - Logitech Z906 5.1 - Custom Water Cooling Loop
Mobile: Samsung S8 Plus | Headphones: Audio Technica ATH-M50X / ASUS Strix Pro | Laptop: Alienware 17 R2
https://linustechtips.com/topic/336424-help-please/#findComment-4590804
What did you do?
Raised the multiplier too much? Just reset the bios - Either there should be a reset switch on your motherboard or just take out the battery for few mins(also disconnect all other wires from the I/O) and then just put it back in
If you pushed too much voltage it may be that you fried something but to be sure, just do a BIOS reset.
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/336424-help-please/#findComment-4590814
your gonna have to pull out the battery .  try doing that . hopefully you didn't burn anything out . not realy and OC board
Surely there wasn't enough voltage going through to cause too much of a problem. Might just stick with a mild overclock then - have removed the battery for a few minutes now, will wait a little bit then put it back in. Does this reset the BIOS?
https://linustechtips.com/topic/336424-help-please/#findComment-4590885
Yes.
https://linustechtips.com/topic/336424-help-please/#findComment-4590893
