144 hz help.
Go to solution Solved by Notree,
HDMI is your problem. Use Display port or DVI-D.
I'm confused the most I can change my refresh rate is 60hz when I have a 144 hz monitor. I have a gtx 980. Tried it with Tomb raider but it capped at 60.
What cable are you using?
Also did you change it through Screen Resolution in Windows?
https://linustechtips.com/topic/336409-144-hz-help/#findComment-4590632
Simple question, is V-Sync on
Please ignore.
https://linustechtips.com/topic/336409-144-hz-help/#findComment-4590639
HDMI, And I went to advanced settings and monitor but it seems to be stuck at 60 hz
You could overclock your monitor as HDMI won't normally allow above 60Hz.
Get a Dual Link DVI-D or DisplayPort
https://linustechtips.com/topic/336409-144-hz-help/#findComment-4590735
