SSD and OS Help
Go to solution Solved by Timopomer,
How can i reinstall the OS and delete it on the HDD
ok easy.
put all "other shit" on HDD in a place you will easily find it.
turn off computer.
plug out the HDD.
plug in SSD
get an operating system disk/flash drive and install operating system on SSD.
once finished
turn off pc again
plug in HDD and make sure the pc is set to boot from SSD and NOT HDD /
OR get usb to sata enclosure to hotswap the HDD into the computer whille turned on.
copy "some shit" to SSD if possible and completely format the HDD
the easier way is get a third hard drive
copy shit to third HDD
turn off pc
plug out old HDD
plug in SSD
turn on pc
install OS on SSD
turn off pc
plug in old HDD and third HDD
turn on pc
format old HDD
copy shit from third HDD to old HDD
done
Reinstall the OS. There are some applications out there that will allow you to do that, but they are quite hard to find.
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/336287-ssd-and-os-help/#findComment-4589046
ok easy.
turn off computer.
plug out the HDD.
plug in SSD
once finished
turn off pc again
turn off pc
plug out old HDD
plug in SSD
turn on pc
install OS on SSD
turn off pc
turn on pc
format old HDD
done
https://linustechtips.com/topic/336287-ssd-and-os-help/#findComment-4589091
