So after getting my new GPU I overclocked it getting 1170Mhz on the core and 1700 on the Mem.
That ran fine when I was actually overclocking it (With furmark) but when I launched 3D Mark and ran the Fire Strike benchmark it wouldnt clock above 950 mhz.
Power limit is on +25, card is Amd R9 280X Vapor-X.
My GPU History: GTS 250, 7790, 7850, GTX 660ti, 7870XT, 7970, 280X, 280X Crossfire, 290, 290X, Fury X, 390 Crossfire, Fury Crossfire, 1070, 1080, 1080ti.
My CPU History: Pentium 4, Pentium E5300, Core 2 Quad QX 9650, Intel Xeon 1230 v3, 4790K, 3930K, 5820K, 1700, 3700X.
https://linustechtips.com/topic/336152-card-wont-overclock/
what you use to read the GPU speed?
was it GPU-Z ID or Afterburner?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587140
Where are you finding out it won't go above in the benchmarks? Are you using in-game core clock because it has never been accurate..
Or can you literally not hit speeds above it..
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587147
First thing that comes to mind is thermal throttling. Maybe keep an eye on those temps.
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
    Asus Maximus VIII Hero
  • RAM
    16 Gig of G.Skill TridentZ Series 3000 Mhz
  • GPU
    EVGA 1070 FTW edition
  • Case
    Fractal Design Define R5
  • Storage
    Samsung 850 Series 250GB for boot + WD 2TB Black
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587150
Afterburner, and I can also tell because the results coming out of 3D Mark are lower than normal.
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587152
It just wont the the speed.
Temps aren't above 65C
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587157
uninstall and reinstall the GPU drivers
same goes for the Afterburner software or any other OC software
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587165
Next thing on the list would be power delivery and making sure the drivers are up to date. By power delivery I mean making sure you have the overhead on your PSU. A good way to check is build your pc on http://www.pcpartpicker.com. It'll give you a wattage estimate and if you aren't clearing that then it may be your problem.
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587168
Running Omega, Tried reinstalling drivers. Power delivery is fine, I'm running a 620W PSU(Single 12V Rail.).
Btw it won't even run at factory overclocked speeds of 1070Mhz.
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587179
use this
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
then install back the latest driver
download only Afterburner
set power to 110% or 120%
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587192
Well shit... Maybe a badly binned GPU. I'd screenshot your results and email the manufacturer. Worst case RMA.
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587206
Nope. It ran fine at 1170 before.
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587225
Huh...
The card changes clock as it runs. The only thing I can think that 3Dmark is pulling the clock at the end of the run or giving an average. Below is a good example.
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587273
Huh...
Not that.
It goes up to 1170 Mhz when I turn the computer on (The first 2 big spikes) then the big chunk is in 3D mark, and just as a control the next big chunk is Goat Simulator (First steam game I clicked)
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587302
*snip*
I mean just looking at the graph I don't seen any correlation with the clock dropping versus anything else that would cause the issue. I'm sorry I couldn't be more help.
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587357
Thanks. I ended AMD external events monitor and it clocks back up to 1170... Maybe that's why it manages it right at the start? Do you happen to know what that process does?
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587383
Sounds like it's part of the driver package that's included in the catalyst software. According to this http://www.rage3d.com/board/showthread.php?t=33959271, it has something to do with hotkeys. Outside of that I'm not sure.
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587413
Ok scratch the AMD thing, it's 3D mark itself... Like wtf! With 3D mark open, it will max out at 950Mhz, when it's closed, it will go to 1170 Mhz... What the actual fuck?
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587422
Is it the free version of 3Dmark? If it is maybe that would have something to do with it. Not sure.
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587428
ok update the program
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587429
That was my first assumption. Might try buying it...
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587536
It just updated. Maybe that's the problem.
https://linustechtips.com/topic/336152-card-wont-overclock/#findComment-4587560
