Hello everyone
im using the gigabyte z77-hd3 motherboard
i got a little problem while booting up the pc
when press the power button, the pc will boot into the motherboard logo screen
thats the problem, because it will just stop right there, until i press enter, then it will continue to boot into windows
can anybody help me to solve this plzzzz??
also the windows booting logo and the motherboard logo are on the secondary screen, kinda bug me, can you help me with this???
thank you
https://linustechtips.com/topic/336133-boot-problem-with-motherboard-solved/
check your boot device priority, and you can set the primary gfx device in the bios, should get it to the correct screen...Or just switch the cables on your GPU
is fast boot enabled?
boot device priority, and you can set the mobo to use the GPU as the first boot display in the bios, should work
if not clear CMOS and see if works
otherwise update the BIOS
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
