If it is a new PC, some Windows updates need others installed first before they can install. So there is often multiple cycles you have to go through to get all of them out the way. The rainbows are probably unrelated but can try reinstalling the gpu drivers once Windows is done.
If its a fresh install, you'll be doing updates for days, maybe even weeks.
