xbox networking need help please
i have to admit that as much as i know about PC's i'm not that advanced in specifically the area of networking, never had a reason to learn so i guess the time to learn is now. i have no idea what NAT type is. so if you could give me some more info about NAT types and ports i would be appreciative.
Ah okay, well you will need to go into your router control panel and figure out how to port forward. Every router is different. I would recommend looking up instructions by your model numbers.
You can find the ports that need to be forwarded here: https://support.xbox.com/en-CA/xbox-360/networking/network-ports-used-xbox-live
You need to go into your advanced network settings on your xbox and find the local IP of your xbox, then port forward to that IP.
