Hi guys,
do you think that when The Crew stutters it could be related to the Vcore? At stock it doesn't stutter (just a tiny little, less than OC'd, that's the reason of my suspects)... Could it be another way to know when the OC is stable? (im testing it with the "didnt crash yet" method lol)
Regards,
EMENCII
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/
Did you stress test it using Intel Extreme Tuning Utility?
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/#findComment-4580741
More or less... But I was avoiding that method, because... Well, there's not actually a valid reason, was just asking a stupid question ^^'
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/#findComment-4581741
That's the first thing to do to test for stability issues.
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/#findComment-4582011
Hi guys,
Regards,
EMENCII
internet connection related issue.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/#findComment-4584872
You sure? That would be so relieving...
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/#findComment-4588273
i'm pretty sure yes...that game isnt very hard to run and it's a 100% online game...monster world...lots of players...if it stutters i'm quite confident that it's because your internet connection is not stable enough/not fast enough.
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/#findComment-4588392
Mmh, would be beasically the only game... 10Mbps (italy T_T) glass fiber with a speedtest ping of 2ms... Never had problems... Almost... :D
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/#findComment-4588861
maybe it's just the server you where connected to?
https://linustechtips.com/topic/335770-cpu-vcore-and-stuttering/#findComment-4588882
