I have recently swapped my laptop, for desktop. But the desktop I replaced my laptop with has a ( at least I think so ), mbo failure, it gives error code "99". Currently it has Amd phenom x4 955 be, and mbo is asrock 970 extreme4. I have around 65 $ ( in my currency 450 kn, consider I live in Croatia ) and I am looking for mbo that can support my current processor and later fx 8000 series processor in future.
I'd like if you could provide me with link to croatian pages ( instar, futura it, links, nabava.net - names of websites that are dealing with pc parts ), also link to product it self would also count.
Thanks.
https://linustechtips.com/topic/335071-help-thanks/
You cannot buy a motherboard which can support both the AMD Athlon series and the AMD FX series.
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/335071-help-thanks/#findComment-4569876
He said Phenom, and Phenom uses the AM3 socket, which is compatible with AM3+. Please don't talk about stuff if you have no clue what you're on about.
Where are you buying from @Lass ? (which website)
https://linustechtips.com/topic/335071-help-thanks/#findComment-4570286
Here are links to web :
- http://www.nabava.net- in search bar you type what would you like to search and it will provide you with links adequate to your search, with prices listed ( in Kn - currency ) from different shops.
- http://www.instar-informatika.hr
- http://www.links.hr
- http://www.futura-it.hr/naslovna/
Quick translations :
Komponente - components
Matična ploča - motherboard
Thanks
https://linustechtips.com/topic/335071-help-thanks/#findComment-4570475
Oh, forgot to mention al the trpubleshooting was alredy done, did as many things as possible. Still error, cant get to bios or to boot.
...btw remove ALL USB devices and try that too (Even keyboard or mouse if they are USB).
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/335071-help-thanks/#findComment-4580309
