NEED HELP please!
Go to solution Solved by NoExceedingMe,
I have not opened anything, will get a network card that goes into mobo later on
I bought the MSI h81m-p33, as well as the Pentium g3258. But I recently discovered that if the bios on the motherboard is not factory updated, I won't be able to use the CPU, as some h81 motherboards may need a bios update prior to using haswell-refresh CPUs. So I will be returning that motherboard, and I want to get the MSI Z97 PC MATE. Can you please look over my build and tell me if there are any compatibility issues and if the mobo will work with CPU without needing to be updated, and if windows 7 works with all the parts. Thank you !
http://pcpartpicker.com/p/TzJy7P
All the parts of the build I linked I bought except the motherboard, which is the one I want to get.
https://linustechtips.com/topic/334918-need-help-please/
97 series work out of the box with G3258 and all Haswell Refresh chips.
http://ca.msi.com/support/mb/H81MP33.html#support-cpu
Have you tried updating the BIOS?
Current build: Konata-ROG
CPU: Intel i7-4790K, 4.4GHz @ 1.2V | Mobo: ASUS ROG Maximus VI Impact | Cooler: H80i GT with 2x Silverstone Air Penetrator 120mm | Case: Cooler Master Elite 130| SSD: AData SP550 480GB | HDD: WD Blue 750GB 2.5; WD Blue SSHD 1TB 2.5; WD Red 1TB 3.5 | RAM: Mushkin Redline 2x8GB DDR3-1866 | VGA: Sapphire Dual-X R9 280X | PSU: Silverstone SX600-L
Current build: Konata-HTPC
CPU: AMD FX-6100 (currently at stock) | Mobo: Gigabyte 990FXA-UD3 | Cooler: Silverstone AR-06 | Case: Silverstone GD10 | SSD: AData SX900 256GB | RAM: ADATA XPG 2X4GB DDR3-1600, Kingston HyperX 2-4GB DDR3-1600 | VGA: MSI HD7950 Twin Frozr III | LG Blu-Ray PSU: XFX TS 750W
https://linustechtips.com/topic/334918-need-help-please/#findComment-4566978
