so my problem is when im playing my pc it would just restart randomly and it would give me this message after it boots back up, i have no idea what to do and i want my pc to stop restarting randomly please help.
Problem signature:
  Problem Event Name: BlueScreen
  OS Version: 6.1.7601.2.1.0.768.3
  Locale ID: 1033
Additional information about the problem:
  BCCode: 124
  BCP1: 0000000000000000
  BCP2: FFFFFA80084C44A8
  BCP3: 0000000000000000
  BCP4: 0000000000000000
  OS Version: 6_1_7601
  Service Pack: 1_0
  Product: 768_1
Files that help describe the problem:
  C:\Windows\Minidump\032415-28735-01.dmp
  C:\Users\Brandon\AppData\Local\Temp\WER-97984-0.sysdata.xml
Read our privacy statement online:
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
https://linustechtips.com/topic/334693-please-help-me/
-snip-
Can you upload and link the dump file?
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/334693-please-help-me/#findComment-4562417
that.
https://linustechtips.com/topic/334693-please-help-me/#findComment-4562592
It sounds like it fails under strain, usual causes to this are  overheating, under powering something, and sometimes its caused by ram that is starting to go bad. If your power supply is sufficient it still could be under powering do to loose wiring or your power supply is starting to fail.
It also could be software related so that .dmp file will be a lot of help narrowing down what is the cause.
https://linustechtips.com/topic/334693-please-help-me/#findComment-4567475
I agree. The 124 error  code points to a hardware issue, so check the temps, if it gets too high, see about a new heatsink. if you are OverClocking, I would reset everything to stock and see if it helps.
Did this happen while playing high graphical games, or heavy editing?
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
https://linustechtips.com/topic/334693-please-help-me/#findComment-4567527
