I've been coming back to this and the 24pin will not go in!! all the pins look fine! do you think it's okay for it to be like this?
http://imgur.com/oWDXVnW
http://imgur.com/OT5e0rH
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/334652-24pin-wont-fit/
Same for me, I left it just plugged in as far as I could get it and have had 0 problems with it.
https://linustechtips.com/topic/334652-24pin-wont-fit/#findComment-4561444
No. Take it out and make sure nothing is in it. It sometimes takes some pressure to push it in.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/334652-24pin-wont-fit/#findComment-4561447
my fingers hurt from pushing on it...
https://linustechtips.com/topic/334652-24pin-wont-fit/#findComment-4561458
Heh, my first ever build failed to start up initially because the 24-pin connector didn't go all the way into the motherboard. I've found it always takes a surprising amount of force to get that thing in there. You might be facing a similar issue.
https://linustechtips.com/topic/334652-24pin-wont-fit/#findComment-4561486
I took a toothpick and started pushing pins that were not completely center and it went in a little farther
https://linustechtips.com/topic/334652-24pin-wont-fit/#findComment-4561559
