hi i am looking to build a new rig but i have a problem i cant find any good am3+ mobo's that are micro atx, have usb 3.0 header and support minor overclocks.
the cpu i want to use is the amd fx-6300, gpu is gtx 650 ti boost. the best mobo i was able to find is http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128565    .
if i get an a10 apu will i be able to use virtu lucid mvp thing with it to get more preformance??
thanks,
https://linustechtips.com/topic/33407-motherboard-help/
The Asus ROG Crosshair series supports the AM3+ sockets but they do cost quite a lot.
http://www.asus.com/ROG_ROG/CROSSHAIR_IV_EXTREME/
http://www.asus.com/ROG_ROG/CROSSHAIR_V_FORMULAZ/
http://www.asus.com/ROG_ROG/CROSSHAIR_V_FORMULA/
Edit - Woops, didn't read through your post properly, these motherboards aren't Mirco-ATX
https://linustechtips.com/topic/33407-motherboard-help/#findComment-427254
but they are high quality
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
https://linustechtips.com/topic/33407-motherboard-help/#findComment-427256
