Need help. Audio
Go to solution Solved by adamsjus1,
I just disabled the headphones that it thought was playing the sound. Everything works now! Yay
I must have done derped somewhere
But none of my sound is working except for Skype.  Like I can hear when I get messages and when someone is calling me and stuff with my speakers and my headset.
But everything else doesn't work. Pandora doesn't work.(it says its playing but can't hear anything. Can't hear anything on youtube. Can't play any music anywhere!!!
Also there is no audio to any of my games.
How do fix!!!!!
https://linustechtips.com/topic/333623-need-help-audio/
How do fix!!!!!
Click on the speaker icon in the bottom right then click mixer. Check in there to see if you changed anything. If you have yesterday's backup you can always roll back.
https://linustechtips.com/topic/333623-need-help-audio/#findComment-4526814
Okay so I found the icon. It says the audio is going out headphones.   Its not. I can change it to speakers and when I click the volume thingy I hear the pep. But no music or sound of any kind!
https://linustechtips.com/topic/333623-need-help-audio/#findComment-4526881
