Hello! I have a few questions regarding graphics cards.
First of all, here is my setup so you know what I'm running;
Intel Core i7 4770 CPU @ 3,4GHz
Asus Z97-A Motherboard
2 sticks of 4gb DDR3 RAM @ 1600MHz
Corsair 750W RM series PSU
Gainward GeForce GTX760 2GB
My first question is this;
I want to run 3 monitors @ 5760x1080p. Is this possible?
Do I need another graphics card with SLI?
If so, can my Gainward GeForce GTX760 2GB run SLI with an
ASUS GeForce GTX 760 2GB?
Can my 750W PSU handle 2 graphics cards?
Any pointers and help is greatly appriciated
Thanks!
https://linustechtips.com/topic/332265-need-help/
VRAM doesnt stack so the only benefit you would get is added performance and that is not guaranteed.
Just sell your current card and get a r9 290.
https://linustechtips.com/topic/332265-need-help/#findComment-4509848
since you have only 2gb ram that will limit your performance in a 3x1080p set up. you could sli and run it at lower texture quality and no aa but i'd recommend going with a single 290x. for the price, you'd get much better performance.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/332265-need-help/#findComment-4509906
