Hey y'all, i was just curious to see for those of you that have GTX 980's what kinds of Clock speeds and Temps you are getting.
i have a EVGA GTX 980 SC (04G-P4-2983-KR) and i'm just using the default Percision X settings (custom fan Curve of course) and getting boost Clocks of 1404Mhz and havent seen it go above 60C
https://linustechtips.com/topic/332264-gtx-980-clocks-temps/
On my Benchmark profile I have it boosts to 1540 with KBoost on and my card doesn't get above 62 degrees. ACX 2.0 cooler.
Ryzen 7 3700x | Gigabyte X570 Aorus Pro WiFi | TForce Delta 32GB DDR4 | WINDOWS 10 64 BIT | WD Black 1TB NVME | Intel 1TB NVME | WD Black 4tb HDD | Nvidia 3080 FE | Seasonic 850w Platinum | Fractal Design Meshify C Tempered | BeQuiet DarkRock Slim |
https://linustechtips.com/topic/332264-gtx-980-clocks-temps/#findComment-4509846
how loud is your ACX 2.0?? like what speeds do you have it set at for the 62C mark?
On my Benchmark profile I set my fans at 75% and not on auto.
https://linustechtips.com/topic/332264-gtx-980-clocks-temps/#findComment-4511031
