Looking to spend less than $80 to set up my GTX780 with water cooling
is there an inexpensive wtaerblock out there or should i just use a bunch of these?
http://www.aquatuning.us/water-cooling/gpu-water-blocks/mini-blocks/10763/alphacool-mcx-one-copper-edition
with the mini blocks, the GPU cooler, the thermal adhesive, and the splitter, it comes out under $80
also, is it worth the added security to go with a full cover water block?
https://linustechtips.com/topic/332193-gtx-780-water-cooling/
80$ is not enough for proper water cooling, it can result in problems later.
Just don't bother.
https://linustechtips.com/topic/332193-gtx-780-water-cooling/#findComment-4509144
