When I play games, even Team Fortress 2 my PC  radiator water cooler got really hot and so did my processor. My whole PC was very dusty which was ultimately the problem and was what I thought the problem was of my PC freezing. So today I completely air dusted my computer and well my PC no longer overheats. However, it still freezes. I think my PSU could be bottle necking which causes it to freeze
Specs :
PSU : 600W CX600M
GPU : R9 270x Toxic OC
CPU : AMD FX-9590 ( 225W TDP )
Case : T28 Sharkoon
Motherboard : GIGABYTE GA-990FXA-UD3
CPU Cooler : Seidon 120v
Hard Drive : 500GB Western Digital
RAM : 8GB
https://linustechtips.com/topic/331657-pc-freezes-help/
probably over heated because of AMD  xD
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4502656
That font size and when i read freeze i thought your processor gets too cold,after cleaning up dust xD
  • Check for malware
  • Update windows
  • Update Motherboard drivers
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4502683
Does it freeze as in lock up with no restart? Or does it just randomly restart? What temps are you getting in HWMonitor? Check your +12V rail output in both the BIOS and HWMonitor, does it fluctuate more than 1-2V?
Check Windows Event Viewer, take a screenshot of it if there are any critical events and post it here.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503311
PC just freezes and then I have to restart it. Not sure what you mean about the BIOS etc??
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503343
Download and install this: http://www.cpuid.com/softwares/hwmonitor.html
Run it and take a screenshot of the window showing everything on it and post it here.
Open Control Panel, select Administrative Tools. Open Event Viewer. In the main window under Overview and Summary, you'll see several columns. Under Event Type the first one is Critical, if there are any errors under that selection, take a screen shot of the window and post it here.
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503426
Okay thanks will do now!
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503432
Here are the screen shots
http://gyazo.com/b79b3e19472ed17ceba8288700ad9082
http://gyazo.com/b604f7f1b13d91547f97357f5cffc29b
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503476
It seems like code 41 is most likely a faulty PSU. Check that all the cables are plugged in properly on both ends. Also try using a different socket in the wall as it could be something electrical. If you have a surge protector try not using it
What is a surge protector??
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503523
Nope never overclocked
How old is your CX600M? How long have you had this system running? The 600W CX series isn't the highest quality, and as it's only Bronze rated, it's not actually pumping out a full 600W, more like 560ish. Considering there is a Kernel Power event in there twice in the last 24 hours, I wonder if you're exceeding the PSU's abilities.
I ran your config through a PSU calculator and came up at 562W, give or take a fan or two, and that's not including capacitor aging.
Now this doesn't rule out things like bad RAM, but I'd say it's a high probability that your PSU can't handle your system. That's one power hungry CPU you have in there.
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503524
I think so? Is it basically just a the power cable adapter things so you can have more things plugged in at once? If so I am using that.
Yes and no. Some extension cords have surge protectors but I'm pretty sure you don't. A surge protector does what the name implies. If something goes wrong with your electricity it prevents your computer from getting fried due to high voltage spikes.
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503591
Okay, so what do you think is causing my PC to freeze?
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503594
I don't think this is a bad power bar issue. That would be much more random than this.
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503605
This ^^^
Don't take that as you need to run out and buy a 1200W PSU. I would suggest a RM750 by Corsair to allow for a future card upgrade or something along those lines. However, if the RM is out of your price range for the moment you can upgrade to a CX750 as well.
RM: http://www.amazon.com/Corsair-80PLUS-Gold-Certified-Power-Supply/dp/B00EB7UITQ/ref=sr_1_4?ie=UTF8&qid=1426883502&sr=8-4&keywords=750+watt+power+supply
CX: http://www.amazon.com/Corsair-Builder-Bronze-Certified-Supply/dp/B008RJZQSW/ref=sr_1_3?ie=UTF8&qid=1426883502&sr=8-3&keywords=750+watt+power+supply
FOR THE WAFFLES!!!
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503606
Okay, any other PSU ideas? What should I get instead.
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503610
This ^^^
Willisaurus is dead on with the recommendations. A Seasonic G series like the G750 is also an excellent choice, or the EVGA G2 series. I have heard good things about XFX also. Lots of choices. Keep it at 750W-800W and you'll be set for a good long time.
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503621
Okay, how is this http://www.amazon.co.uk/Seasonic-S12G-750-750W-Certified-Silent/dp/B00GSJRDKW/ref=sr_1_1?ie=UTF8&qid=1426884046&sr=8-1&keywords=Seasonic+G+750
https://linustechtips.com/topic/331657-pc-freezes-help/#findComment-4503629
