just saying its not my PSU its my mates
so the issue is when he comes out of a game e.g. game finishes on CSGO the PSU fan goes 100% for a second or two other wise its fine but what could be causing this he has a AX650 with a i5 4690K with a MSI GTX970.
when he had a 660TI and i3 2220 it did not do it
its not a huge issue just wondering why it does it?
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/331215-loud-fan-issue/
Well, I'm guessing there is a cut-off temperature where the fan speed changes and it's bouncing up and down between that. Can you change the fan curve on the PSU? If you can't then you probably just have to live with it.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/331215-loud-fan-issue/#findComment-4496607
yeah i guess its strange because its silent the whole time the 100% lol oh well not my problem i guess
PC PART PICKER
https://linustechtips.com/topic/331215-loud-fan-issue/#findComment-4496618
