Hi all,
I am thinking of getting myself the new CM Seidon 240M. I read some good things about it on some reviews but I would also like to know how your personal experiences are with it?
Also I want to get myself the CM HAF XB and I believe that it fits in there....
Also I want to mount it in the front of that case and want to use some of my blue LED fans I currently have. (possibly not use the stock fans with the Seidon). I have Zalman ZM-F3BL fans. Can I use 4 of these in a push/pull config for that rad? Or any other fans better to use (blue LED fans). Any advice?
Thank you :)
CPU: AMD FX 8120 @4.5Ghz - CPU cooler: Cooler Master Nepton 240M Watercooling - Mobo: Asus M5A97Pro - GPU: Sapphire Radeon R9 280X Vapor-X @ 1200Mhz - Memory: Kingston Hyper X 16GBs DDR3 - Storage: Kingston SSD & Seagate Baracude HDD - PSU: Cooler Master V850W PSU- Case: Cooler Master Cosmost II
-- Build Log old PC (HAF XB): 'the Cube': http://linustechtips.com/main/topic/36288-the-cube-cooler-master-haf-xb/ --
https://linustechtips.com/topic/33081-cooler-master-seidon-240m/
Yes the cm seidon is a pretty good cooler and yes you can fit it in a cm haf xb and yes you can go with push and pull with that rad and the best blue led fans are gelid wings http://www.newegg.com/Product/Product.aspx?Item=N82E16835426024
You can't walk out of your own story - Rango
https://linustechtips.com/topic/33081-cooler-master-seidon-240m/#findComment-422933
Thanks but any idea if the fans I already have will be good for it? http://www.zalman.com/global/product/Product_Read.php?Idx=199
https://linustechtips.com/topic/33081-cooler-master-seidon-240m/#findComment-422938
No there no good there pretty bad fans if you want good cheap blue led fans then I reccommed bitfenix spectre pros http://www.newegg.com/Product/Product.aspx?Item=N82E16835345037 Edited by everything count to life
https://linustechtips.com/topic/33081-cooler-master-seidon-240m/#findComment-422958
Thanks for the 2 recommendations but any input why my zalmans are bad? I have 4 of them now in my case and they are not loud or anything at all.... !?
https://linustechtips.com/topic/33081-cooler-master-seidon-240m/#findComment-423115
And possibly, what would you suggest? CM Seidon 240M or Corsair H100(i) ?
https://linustechtips.com/topic/33081-cooler-master-seidon-240m/#findComment-432343
