Antminer no-lights?
Go to solution Solved by HEU7Hwhu7,
Got it! :D I had the two PCIE's in the same group.
Hello,i just got my Ant miner s3 and there are no lights when i power it on,fans spin etc,it's connected via my router. Any help?
Why you spend that much on one is beyond me... But is it plugged in? Switched on? Does it have lights?
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/330622-antminer-no-lights/#findComment-4488758
Fans on, PSU is on,no status lights for ethernet or red or green lights. got it on eBay for $100
Well, I can't guide well, but just in case you didn't get one... here's a manual
https://bitmaintech.com/files/download/Antminer%20S3%20Manual_EN_2014.7.16.pdf
https://linustechtips.com/topic/330622-antminer-no-lights/#findComment-4488791
