Possible processor woes
Thanks for your prompt reply. I would undervolt it but like I said it was unusually high temps given my E6600 runs at 1.250V VCORE max. I did not want to run high volts on the processor because I was hoping this would last me for at least 5 years and anything to decrease the lifespan was a big no-no. Should have gotten a 4670K like you at since they are from more established Costa Rican fabs.
Different chip, different temps. You have to understand that the input voltage isn't what wears on the chip, that's the VCore. Input voltage typically doesn't reduce lifespan much, if by any noticeable amount at all. What I'm saying is decrease Vcore to lowest stable, and increase input voltage to increase overall stability. Reducing Vcore should increase the chip lifespan, reducing temps potentially by quite a bit, if you can manage to go down far enough. Increasing your input voltage should only increase stability. The chip should last for a long time anyway, as most people upgrade their Intel chips just because they can rather than actually needing to. A lot of people still happily use i7-970 chips overclocked and overvolted.
