Ok so i know almost nothing about this stuff but I'm interested and a quick learner. And anyways, i have a build I'm working on so i need to figure this out. So I'm building a portal themed pc and i need to make logo on the front of the case light up. I want to have a switch that has 3 options. Blue, orange, and off. I was looking at the circuit i would need for this and all the parts and i could build it, but idk how i would power it. And i was also wondering if there was an easier way than building this myself on a bread board or something. Like i realize i could use an rgb strip with the remote, but i don't really want to do that cause i only want two colors and a switch instead of a remote (especially cause my entire bedroom is lit by rgb strips) so is there an easier way to do this? If not then how would i power this? Like what parts would i need to keep it from melting or blowing up or something? Sorry I'm new to anything electrical. Thanks :)
Just a normal guy with a constant desire to modify everything he owns.
Check out my current build here:
https://linustechtips.com/main/topic/1006447-the-cake-is-a-lie-water-cooled-portal-pc/
https://linustechtips.com/topic/330090-3-way-led-switch/
You could power it with Molex/SATA power also I think you would need some resistors (not %100 sure on that/what type).
For switches, you could use these:
Or you could use these:
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/330090-3-way-led-switch/#findComment-4483778
