R9 280x temps and fan speed
Shoob
Hello guys,
I've got an R9 280x and it's a great improvement over my old card. But there's a thing that worries me - under load the temps get up to around 74-75 degrees and fans only spin at around 40%. Is that normal or should I try to set them manually? If so, do you have any suggestions about a good fan curve?
From salty to bath salty in 2.9 seconds
my gpu goes to 89oc at 60% fan, you are fine under 105oc.
Listen if you care.
