Hey!
So I just finished my first build, but i´ve been having a problem: When the PC stays turned off for a while and I try to turn it on, it takes a minute to respond and starts to turn on. I´ve already updated the BIOS, but it didn´t solve my problem
My setup:
-Asus Sabertooth Z77
-Power Supply: SeaSonic 850W
-intel I7 3770K
https://linustechtips.com/topic/32988-problem-with-sabertooth-z77-boot/
Uhm... Go into the bios, press the function (F5 i think) key that sets optimized defaults, F10, enter and that should help. (check your boot priority afterwards!) If that doesn't help at all you should contact Asus support.
You can just put the rig to sleep. Powering off doesn't save more power, parts or have an advantage.
